Banned
Did this to my 08 2500 HD and with a little trimming my 20's dont rub. My question is now when I hook up my 27ft enclosed trailer the truck sags in the rear under load. It rode perfectly level before I cranked the bars up. Will air bags level it back out if I buy them? If so what bags should I run? Ive been looking at air lift with the on board controls. Has anyone done this yet? When Im towing Im usually towing 7500 to 10000 lbs. I love the way it looks and rides, just want to fix the towing. Love to hear a reply from someone who has done this already.
__________________
If ya don't want to do airbags, a cheaper solution would be 1" blocks in the rear.
Bags will help your sag issue while towing definitely.
Airlift is the brand to go with. tons of guys around here run them with excellent results. I would recommend the on board air setup for them so you don't have to worry about them getting below 5psi and potentially hurting themselves, plus it just makes life easier.
I have personally installed a firestone kit without any issues, and its a quality kit as well, but when i throw bags on mine in a few months i'm going airlift.
Air Bags will do the trick - my truck settles about 1 3/4 inches when I hook up - I put 45 lbs in the bags to bring it back up about an inch or so.
I use the AirLift 5000 air bags.
if u went from a stock height to a leveled truck it just looks like its sagging now, before gm had it compensated so that it looked leveled for towing purposes
