21 - 40 of 165 Posts
I've got a lifetime drivetrain warranty and I paid extra for a lifetime bumper to bumper warranty as well. BUT, this warranty doesn't cover the emission treatment systems.
This is why you question and read the fine print on extended warranties. Many exclude the very items that chronically go bad. Believe me, they know where the problem spots are on vehicles and know what to steer around. I made sure my ext warranty covered all sensors and emissions items including the DPF before I bought it.
That huge long list of items they say they cover? Most of them rarely go bad and that's why they try to impress people with...Like "We got you".... I've lived this life cycle a few times and now an a wiser consumer....
I knew the emission system wasn't covered when I purchased the policy.
Mind if I ask who your extended warranty provider is? I might have to switch providers.
Well I just had a check engine light present itself yesterday afternoon. Pulled the code and it's P2C7A.
Have a dealer visit scheduled for next Tuesday.
Will update when I know more.
(Currently at ~25,000 miles)
Had an appointment at the dealer today. They diagnosed a bad Cat. Will be another appointment to have it replaced.
Will update after the replacement.
Brand new 2022 Sierra 1500 has been in 3 times and is headed back for a 4th. Truck spends more time at dealer than my house.
First time it was reset computer / clear codes - oh they're history codes they said so no issues reproduced. CEL back on within a day.
Back the next week - same codes - this time it took 10 days - replace cat - CEL on the way home
Back in the next week - replace NOX sensor - home last Friday - today CEL code P2C7A
Headed back tomorrow.... unreal.
Hello fellas, tech Tony here from a local Chevy dealer. This code is going to come back on every time yall use over 20% of fuel tank capacity with bio-diesel (its in the owners manual) ----Doc 4853915
Caution: Do not use home-made biodiesel or home test kits because the quality cannot be verified by approved scientific methods. Do not use raw vegetable oil or other unmodified bio-oils, fats, or blends of vegetable oil with diesel. They could damage the fuel system and engine, and damages would not be covered by the vehicle warranty.
Biodiesel Blends
Fuels with a biodiesel content up to 20% by volume may be used (e.g., named B20). Only use biodiesel blends up to 20% by volume that comply with your country’s or region’s fuel standards.
Caution: Do not use blends containing more than 20% biodiesel. Any engine, fuel system, or exhaust after-treatment system damage would not be covered by the vehicle warranty.
As a renewable fuel, biodiesel provides some environmental benefits. However, biodiesel has unique properties and needs to be handled differently than diesel fuel. Its use presents additional risks and may not be appropriate in all situations. Certain vehicle operating modes increase these risks and should be avoided.
Biodiesel fuel quality degrades with time and exposure to high temperature quicker than Ultra Low Sulfur Diesel fuel. More frequent refueling provides the best opportunity to have a supply of fresh fuel. Storage at hot ambient temperatures will accelerate biodiesel degradation.
If the vehicle is not driven often and uses little fuel, or if it is stored for extended periods of time, avoid the use of biodiesel blended fuels above 5% by volume. When the vehicle is stored for longer than one month, it should be run out of biodiesel to below one-quarter tank, refueled with biodiesel-free fuel, and driven several kilometers (miles) before storage.
#PIP5856: Use of R-99 or R-95 Diesel Fuel - (May 26, 2022)
Subject: Use of R99 or R95 diesel fuel
Brand:​
Model:​
Model Year:​
VIN:​
Engine:​
Transmission:​
from​
to​
from​
to​
All​
All​
2006-2022​
All​
All​
All Diesel Engines​
All​
Involved Region or Country
North America​
Condition
The use of renewable Diesel, R-99 or R-95 has been approved by GM Engineering for all GM vehicles with Diesel Engines.​
Cause
Renewable diesel (RD) is essentially any diesel fuel produced from a renewable feedstock that is predominantly hydrocarbon (not oxygenates) and meets the requirements for use in a diesel engine.​
Correction
B20 fuel is a blend of up to 20-percent bio components and 80-percent conventional diesel, which helps lower carbon dioxide emissions and lessens dependence on petroleum.
All Fuel must meet ASTM D975 diesel fuel standards. Renewable or BioMass fuels have an API of up to 50.
The API can be between 40 and 50, depending on if the fuel is a combination of #1, #2, and the R-99/95 fuel. This fuel is also clear in color when not mixed with other fuels.
Currently, we have four things to examine when testing fuel:
1) Look at the color of the fuel compared to what you normally see in your region. Cloudy looking fuel is an indication that there may be an issue with the fuel.
2) Look for any separation of the fuel. This can be anything from sediment settling or different layers like water being seen.
3) The third test is mentioned above and is the Specific Gravity (API) of the fuel.
4) Lastly, if you take a sample of the fuel, put it in a Styrofoam cup, and place the cup in a drain pan, fuel contaminated with gasoline will certainly melt the cup within half an hour. B20 Biodiesel will also melt in a Styrofoam cup, but will take about an hour.
Subject:Use of R99 or R95 diesel fuel
from​
to​
from​
to​
Brand:​
Model:​
Model Year:​
VIN:​
Engine:​
Transmission:​
All​
All​
2006-2022​
All​
All​
All Diesel Engines​
All​
North America​
Condition
Cause
Correction
I'm not using biodiesel though. They also tested the fuel a couple times ago (API 41) to be sure. Not the issue.
Got the truck back again today by coincidence, and this time they replaced NOX sensor #3 so we'll see if that does anything.
Biodiesel Blends
Thats all good and fine, but there is NOWHERE in our local south FL area that does not sell at least B10 bio. And my vehicle sits on occasion 1+ month at at time. I do dump a can of sea foam in for storage, I hope that is good enough……
Yeah it's not great. In a normal market we'd have already done this and be in a different truck but since supply is so low we gave them more attempts to repair.
Punchline is the truck drives well and I really still want one, so now it's go through the buyback process then wait months for another one.
At least you have lemon law/buyback in the US, I don't believe we even have that option up here in Canada (unless someone on here knows otherwise). I hear what you are saying though, the LM2 are nice, comfortable, quiet tucks that get good mileage and are capable for most who only want/need a 1/2 ton. I really do like mine and knock on wood have not had any issues thus far (though I did have to reset two P26BB codes in the first 675 kms, but they have not come back in 4000 Kms). Hopefully it keeps up...
I have the same code and getting the 65mph speed warning. I have an appointment next week but I’m not covered under warranty. I can’t imagine the cost I’ll pay if I need to go in as many times as you.
Biodiesel Blends
Question for you. If your warranty was up and I am getting this code and having my warning for 65mph max speed what would you do.
