Today noticed that the level indication was about 1 segment above half when left work. Did some errands which had to start and stop truck a few times. After about the third time starting, the indication was now 1 segment down from full. About three months ago suddenly all the segments went out indicating an empty DEF tank but had just topped off with about 2.5 gallons of fresh DEF fluid. There was also the appropriate message displayed in the DIC. Close to dealer so stopped in and read for any error codes and none showed up and by this time the segments had returned indicating about two below full. Have kept track of mileage and date when top off tank and usually get about 6k miles for about 2.5 gallons. The indication after work was with about 1.5k miles which was quite a drop. Did not do any heavy towing or speeding which increases the usage of DEF so thought there was a problem with the DEF system but with the level indication now about what should be at wondering if anyone else has experienced anything similar. How is the level in the tank determined or what is used? Is there even some sort of float inside the tank at all?
