2023 2500AT4 ran def until it didn’t show on the gauge in the DIC. never got any warning. Took to dealer for oil change and some updates. Service guy said that was normal. I need to watch the gauge. Does this sound correct? My 2014 gave a warning
Last (partial) segment isn't out yet.2022 Sierra 2500 HD - 38663 miles DEF Completely empty, and zero warnings .. i’m not complaining or anything lol but has anybody seen this happen besides me? View attachment 1121654
10-4 like I said I’m not mad about it for obvious reasons lol just found it odd, my 2018 duramax would have had a fit in the same situation.I started this thread. Mine has yet to give any warning or low messages. The manual says it should.
Some people play with fire and just haven't been burned yet.I've been reading/following GM dmax forums since before DEF came into use. (other forums longer than this one).
I don't buy the argument that def problems are because the tank is allowed to get low.
I've noticed there are posters that seem confuse the 'service emissions' warnings and countdowns with the def level warnings. Both can lead to a lower speed limiter, but with different steps/warnings to get there.
With the LML, I regularly waited for the 300 miles to empty warning to add def, and always waited for at least the 1000 miles to empty warning. ( LML did not have the dic page with would show approximate def level when it was less then 30%. It only gave had the 1000 mile warning once, and then the 300 mile warning. It would update the the miles to empty when restarted. )
With L5P, LM2 and LZO, I regularly take def tanks to empty....just to see the 'miles to empty' warning progression and then when it says it's empty to see the 'miles to speed limit' counter.
These pics were with on my 2018 L5P.
The 'miles' will countdown mile-by-mile as it is drive.
Yes!It doesn’t bother me so much that the DEF level gauge isn’t precise. My RV’s holding sensors aren’t precise either. What bothers me is that that it “thinks” I’m about to run out of DEF when the tank is actually full. And then it threatens me with limiting my speed, and potentially limp mode. -That’s the bigger issue here.
It’s ridiculous. DEF has been around long enough that the related sensors and injectors and heaters should all be working without any worry from the operator/owner. It’s just water and Urea. And it’s just for the emissions system.
Didn't say any of them were 'good' for our trucks.You can do as you wish with your truck, but DEF, EGRs and DPF are not good for our trucks, If you ever seen the inside of an EGR you know it can't be good.
