def problem service exhaust fluid system
52K views 13 replies 9 participants last post by  Mr krabz
Hi guys I have 2011 savana had service exhaust fluid system message came up short time later limp mood started 55mph max speed took to dealer they replaced reservoir cleared codes which where p20b9 and po674 picked up truck drove two blocks message came back on dash??? 2011 savana 3500 6.6L
delete it, problem solved
#3 · (Edited)
This is about all I can tell you that I know.
https://service.gm.com/gmspo/mode6/pdf/2011/11OBDG11 Engine Diagnostics.pdf
P20B9 - Reductant Heater 1 Control Circuit
P0674 - Glow Plug 4 Control Circuit
I would have thought changing the DEF tank would have cleared up the heater code. The DEF tank has a heater in it.
Maybe a bad glow plug or a connection is loose. Hard to say.
I would take it back to the dealer. Did they do a regen after the codes were cleared?
DTC P204F
Diagnostic Instructions
•Perform the Diagnostic System Check - Vehicle (See: Testing and Inspection\Initial Inspection and Diagnostic Overview\Diagnostic System Check - Vehicle) prior to using this diagnostic procedure.
•Review Strategy Based Diagnosis (See: Testing and Inspection\Initial Inspection and Diagnostic Overview\Strategy Based Diagnosis) for an overview of the diagnostic approach.
•Diagnostic Procedure Instructions (See: Testing and Inspection\Initial Inspection and Diagnostic Overview\Diagnostic Procedure Instructions) provides an overview of each diagnostic category.
DTC Descriptors
DTC P204F
•Reductant System Performance
Diagnostic Fault Information
Typical Scan Tool Data
Circuit/System Description
The selective catalytic reduction (SCR) system reduces oxides of nitrogen (NOx) emissions by injecting a metered amount of diesel exhaust fluid (DEF) or reductant into the exhaust gas stream entering the SCR catalyst. Within the SCR catalyst, the DEF reacts with the NOx to form nitrogen, carbon dioxide, and water vapor. Upstream and downstream NOx sensors provide the engine control module (ECM) with engine-out and tailpipe-out NOx levels. The ECM varies the amount of DEF added by varying the reductant injector duty cycle in response to changes in engine-out NOx levels.
The ECM supplies system voltage to the reductant pump motor. The ECM controls the solenoid by grounding the control circuit with a solid state device called a driver. The driver is equipped with a feedback circuit that is pulled-up to a voltage. The ECM can determine if the control circuit is open, shorted to ground, or shorted to a voltage by monitoring the feedback voltage. The ECM supplies a ground to the low reference circuit. As the duty-cycle increases, the output of the reductant pump increases.
Conditions for Running the DTCs
•DTCs P204B, P204C, P204D, P208A, P208D, P20A0, P20A2, or P20A3, are not set.
•The DEF tank is not empty.
•The engine speed is greater than 600 RPM.
•The battery voltage is greater than 11 V.
•The ambient air and emission reduction fluid tank temperatures are warmer than -7°C (19°F).
•The engine run time is greater than 10 s.
•The DTC runs continuously once the above conditions are met.
Conditions for Setting the DTC
•The ECM detects the reductant pressure did not reach a calibrated pressure after an initial attempt to build up pressure. The ECM will then reduce reductant pressure and then attempt to build pressure again. If the ECM detects reductant pressure is still less than a calibrated threshold, a DTC is set. Or
•The ECM detects the reductant pressure is greater than a calibrated threshold or less than a calibrated threshold. Or
•The ECM detects the reductant pressure is greater than a calibrated value in any control state.
Action Taken When the DTC Sets
DTCs P204F is a Type B DTC.
The ECM inhibits the reductant system.
Conditions for Clearing the DTC
Diagnostic Aids
A leak in the reductant system can be determined by inspecting for a build-up of crystallized diesel exhaust fluid (DEF).
Reference Information
Schematic Reference
Engine Controls Schematics (See: Diagrams\Electrical\Powertrain Management\System Diagram)
Connector End View Reference
Component Connector End Views (See: Diagrams\Connector Views\Connector End Views By Name)
Description and Operation
•Diesel Exhaust Fluid (DEF) Warning Strategy (Anti-Tampering) (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Service Precautions\Diesel Exhaust Fluid (DEF) Warning Strategy (Anti-Tampering))Diesel Exhaust Fluid (DEF) Warning Strategy (DEF Level) (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Service Precautions\Diesel Exhaust Fluid (DEF) Warning Strategy (DEF Level))Diesel Exhaust Fluid (DEF) Warning Strategy (DEF Quality) (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Service Precautions\Diesel Exhaust Fluid (DEF) Warning Strategy (DEF Quality))
•Exhaust Aftertreatment System Description (See: Powertrain Management\Emission Control Systems)
Electrical Information Reference
•Circuit Testing (See: Testing and Inspection\Component Tests and General Diagnostics\General Electrical Diagnostic Procedures\Circuit Testing\Circuit Testing)
•Connector Repairs (See: Testing and Inspection\Component Tests and General Diagnostics\General Electrical Diagnostic Procedures\Connector Repairs\Connector Repairs)
•Testing for Intermittent Conditions and Poor Connections (See: Testing and Inspection\Component Tests and General Diagnostics\General Electrical Diagnostic Procedures\Circuit Testing\Testing for Intermittent Conditions and Poor Connections)
•Wiring Repairs (See: Testing and Inspection\Component Tests and General Diagnostics\General Electrical Diagnostic Procedures\Wiring Repairs\Wiring Repairs)
DTC Type Reference
Powertrain Diagnostic Trouble Code (DTC) Type Definitions (See: Diagnostic Trouble Code Descriptions\Powertrain Diagnostic Trouble Code (DTC) Type Definitions)
Scan Tool Reference
Control Module References (See: Testing and Inspection\Programming and Relearning\Control Module References) for scan tool information
Circuit/System Verification
Note: Diesel exhaust fluid (DEF) that is frozen could cause this DTC to set.
1.Ignition ON, observe the DTC information with a scan tool. DTC P1043, P1044, P1045, P1046, P1048, P1049, P202E, P2047, P2048, P204B, P204C, P204D, P208A, P208B, P208C, P208D, P20A1, P20A2, or P20A3 should not be set.
¤ If a DTC is set, refer to Diagnostic Trouble Code (DTC) List - Vehicle (See: Diagnostic Trouble Code Descriptions\Diagnostic Trouble Code (DTC) List - Vehicle) for further diagnosis.
Note: The diesel exhaust fluid (DEF) and ambient air temperatures must be greater than -7°C (19°F) before proceeding with this procedure.
2.Ignition ON, command the Reductant System Leak Test ON with a scan tool. Allow the pressure to build for 30 s. Observe the scan tool Reductant Pressure sensor parameter. The reading should be between 425-575 kPa.
3.Operate the vehicle within the Conditions for Running the DTC to verify the DTC does not reset. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Circuit/System Testing
1.Test the diesel exhaust fluid for contamination. Refer to Contaminants-in-Diesel Exhaust Fluid Diagnosis (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Testing and Inspection\Contaminants-in-Diesel Exhaust Fluid Diagnosis).
¤ If the diesel exhaust fluid is contaminated, replace the diesel exhaust fluid.
2.Ignition ON, command the Reductant System Leak Test ON with a scan tool. Allow the pressure to build for 30 s. Verify there are no leaks in the reductant lines.
¤ If a condition is found, repair as necessary.
3.Remove the Q61 emission reduction fluid injector from the exhaust pipe leaving the reductant line and electrical connector connected. Place the Q61 emission reduction fluid injector into a suitable container.
4.Ignition ON, command the Reductant System Leak Test ON with a scan tool. Allow the pressure to build for 30 s. The Q61 emission reduction fluid injector should not leak.
¤ If a condition is found, replace the Q61 emission reduction fluid injector.
5.Perform the Emission Reduction Fluid Injector Quantity Test (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Testing and Inspection\Emission Reduction Fluid Injector Quantity Test). The Q61 emission reduction fluid injector should pass the test.
¤ If the injector fails the test, replace the Q61 emission reduction fluid injector.
6.Verify the following conditions do not exist with the DEF system:
•Missing, restricted, or leaking reductant components
•Restricted or plugged reductant lines
•A skewed or shifted reductant pressure sensor.
•Restricted or plugged Q62 reductant purge valve - Stuck closed
•High resistance in the G33 reductant pump motor or Q62 reductant purge valve circuits
•Inspect the harness connectors and the ground circuits of the DEF tank for poor connections.
7.If all components test normal, replace the G33 reductant pump motor.
Repair Instructions
•Emission Reduction Fluid Tank Replacement (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Service and Repair\Emission Reduction Fluid Tank Replacement)
•Perform the scan tool Reductant System Reset procedure after replacing the emission reduction fluid tank.
Repair Verification
1.Install any components or connectors that have been removed or replaced during diagnosis.
2.Perform any adjustment, programming, or setup procedures that are required when a component or module is removed or replaced.
3.Clear the DTCs.
4.Ignition OFF, all vehicle systems OFF, this may take up to 2 minutes.
5.Ignition ON, command the Reductant System Leak Test ON with a scan tool. Allow the pressure to build for 30 s. Observe the scan tool Reductant Pressure sensor parameter. The reading should be between 425-575 kPa and there should be no leaks in the system.
6.In order to clear the DEF lamp, perform the Diesel Exhaust Fluid Quality Test (See: Powertrain Management\Emission Control Systems\Diesel Emissions Fluid (DEF) System\Testing and Inspection\Diesel Exhaust Fluid Quality Test). The DEF lamp should turn OFF once the test is finished.
#14 ·
DTC P204F best diagnostic / help I have read so far for this code Thank you very much for posting !!!
DTC Descriptors
DTC P204F
Diagnostic Aids
Schematic Reference
DTC Type Reference
Scan Tool Reference
Repair Instructions
Repair Verification
3.Clear the DTCs.
