1 - 10 of 10 Posts
Not sure if this is the right forum, but here's my issue. Seems that my % oil life remaining from the DIC is moving alot faster since I got my EFIlive setup. Before, it would be 7500-8500 miles or so before it would get close to 0%, now, around a couple thousand and it's already at 0%. Is there something in EFIlive than changes the range. Just not sure if this is due to my EFIlive or something else. Any ideas? Chris
Dont go off/worry about % thing. Go by miles.
That's what I'm doing now. Just wondering why all of a sudden it would change like that. Twice a year still going to be the norm for me, and just keep checking levels in between. Thanks, Chris
You only change your oil twice a year?!?
Its just a worktruck
Yes. You can change the interval with EFIlive. I have my oil set to 3500 miles and fuel filter warning turned off since I dont have one.
Its table B1405 & B1406. It's in Km so you have to adjust for imperial.
Only drive about 12-13K miles a year. Every 6000 miles or so, usually when my DIC shows about 10% life left or at the end of camping season, beginning of season. Usually Fall and Spring. Always checked level about once a month or before a longer towing trip. Rotella T6 5W-40.
Thanks, I'll look at those tables and see what mine are set at. Chris
I've got 1200 miles on mine when I put my efilive in and new filter...thing still says 100%
From what I am told by a deisel mechanic is that the oil life indicator is an extremely accurate system. It measures all kinds of different things that determine your oil life. I listen to it.
I seem to remember reading about how Gm designed the oil system a while back. If i remember correctly, they logged all kinds of parameters from different vehicles for a couple years and would analyize the oil and the motor. Thats how they determined the parameters for the DIC.
I've gotten up to almost 12k, with 5% still remaining on my 1500. Oil look/felt no different then when i change at 6k.
Doesn't make sense that a manufacture would tell you to do something that would damage the product. Unless thats the goal, to keep you buying cars every 100,001 miles :)
Hey Ass Man!
You're not crazy..I've noticed the same thing. I just reset it and go by my miles.
1 - 10 of 10 Posts
