1 - 2 of 2 Posts
I'm looking for a "how to" article referencing changing the diesel fuel filter with pictures. I had one the last time I changed it but can't find it NOW.
I take the fender liner out, spin the filter off, put the water in fuel sensor in the new filter, screw the new filter on, crack open the bleed screw, pump till diesel comes out the screw, close screw, and pump till completely hard. Then start and if it dies, pump primer till hard again and start again and you should be good.
The thread you want is probably in the DIY section but I couldnt find it in my 10 second search. Ill look a little harder.
http://www.duramaxforum.com/forum/how-tos-diy-write-ups/6286-how-change-fuel-filter.html
I think this link will work for ya.
1 - 2 of 2 Posts
