Hi all.
I need some serious help. This truck has been to the dealer at least five times and each time I get charged $150 for diagnostics. It's an '03 Duramax. I've had diesel in the oil for a long time but the dealers keep turning me away and claim that the fuel line pressure is 160mpa which means that the injectors are ok. So they claim. I had the injection pump replaced and still have 12 qts of diesel after only 800 miles. Checked the lines and they're tight........Now what??? It has been a great truck with 107000miles on it but now she is becoming a thorn in my side. What can I do? Thanks.
PS: Tested the injectors with a snap-on analyzer, injectors 6 and 7 barely make a difference when shutting them off while at idle. Code p1238 came up for injector #6 circuit. Cleared it and all is good but still dumping fuel in the oil. The scanner showed 30mpa on the fuel return line and stated that 30mpa is desired.
