1 - 8 of 8 Posts
Just started getting a exhaust smell in the cab in ideas?
do you have the lb7 or lly? I know I could smell diesel in the cab when my injectors took a crap and dumped so much fuel into the crankcase that it was pushing out of the rear main seal...
*edit* just realized this is posted in the LB7 section. my bad. I would check your injector balance rates!
Lb7
It's not injectors there new
Discussion Starter #6
Seems like smell is coming out of the vents just at crank up
Downpipe came loose at the bottom, exhaust leaks at any of the exhaust gaskets? Check for fuel in oil anyway, something might be loose under the vcs.
moving or stopped? if you are stopped check the air vents at the back and bottom of the cab.
1 - 8 of 8 Posts
