So if one wanted to disable an EGR valve (not remove) to work with a delete tune exactly which connectors would need to be disconnected?
Thanks, Rick
Thanks, Rick
the ones that connect to the EGR valve. There are no sensors or wires on the EGR assembly that are required to be there once the delete tune is flashed. At least i dont recall there being any.
I stand corrected, i was not aware there were connectors under the truck that were required to be disconnected for a delete with the EGR left on.
