DIY DPF Cleaning.....
3 reading
80K views 106 replies 36 participants last post by  Mr smith
My LML is turning 150k miles, and the DPF is acting weird. It's doing that rapid count up from zero grams soot to 20-ish grams, right after a regen.
I've seen others post about it, but this is the first i've seen. So, I ordered this....
It's about $400 for everything, it seems a bit steep.
So. how did it work? Great!
This is about 15 miles after a regen. The soot ran up to 5 grams and stopped. My idle backpressure is 0.00. My freeway cruise backpressure is 0.30 psi and WFO BANGING thru the gears is about 1psi. These numbers were higher before the cleanout.
Access is easy. Jack up the truck and unscrew the DPF pressure sensing tap, and your in! Once you buy the rig, the chemicals are cheap so I'll do this every so often to keep the DPF happy....
1090147
#4 ·
I like their products. I went a different route. I cut open my DPF on the '11 when it was clogged and needed replacing at 175K according to the dealer. Two part mix, don't recall if it was the same product but it came in regular cans not for use with sprayer. Spray the first part, let it sit, spray the second part, let it sit. Then I used a pressure washer to clean it out. Could not believe the crap that came out. Welded it back up and it seems to be working like new.
Cheaper alternative if you have a welder but I also have no doubt the spray in product you used would work well.
Bob. How the hell are you doing? Have not seen much of your words of wisdom.
Reactions: KB3MMX and AlisoBob
#11 ·
Thanks for this Bob. Seems like a nice option before shelling out a ton of money to replace the DPF.
From what you're seeing/reading/feeling - is this a process that is purely proactive maintenance or is this something that can be done by owners with a clog or service message?
Another great find!!
#15 ·
#18 ·
Thank you for the info.
2 questions:
1) Looks like the vid shows doing a car. Do we need more of the chemicals due to a larger DPF?
2) Do you know what happens if you don't do a regen right away?
#19 ·
Thanks for this, Bob. My 2017 is at 138k miles and I'm wondering when I'm going to have to look at DPF maintenance. Then I see this post and I'm now less worried. Appreciate you sharing.
#20 ·
Do you get codes or does it go into limp mode? If not it is perhaps the gauge and/or sensor that is the issue and you are chasing a non issue. FWIW I would be very very careful about aftermarket magic treatments, likely they will do nothing, more likely cause more issues. If the OEM regen is working, all you need to do is drive it far enough to get it hot enough to operate.
#21 ·
I get what you're saying, but I disagree with the notion that it will just keep working as intended. We can watch the DPF degrade over time with more frequent regens and/or longer regen cycles.
#25 ·
In my experience there is little notice before the DPF becomes clogged. On the LML I cut open and cleaned it was working fine regenerating as it should and then one day it just wouldn't regen and threw a few codes. I could not do a manual or mobile regen as it would stop as soon as it started. That's when the dealer told me it needed replacement.
Mine became clogged at about 175K. I'm strongly considering running AlisonBob's solution through my L5P at around 130K just to try and avoid having to cut mine open again.
#26 ·
Bob, Being a big believer in preventative maintenance time for me to try this at about 100,000 miles. The Donaldson filter has been great and I did that right after your initial post. Following up to an earlier question are there implications if the regen is not done right after? Also other than a slight increase in RPM how do I know the car is in regen? 2015 3500 GMC Denali. I ignored the fuel pump warning on the LML and got to spend 12 hours on the side of 85 in downtown Atlanta and pay for a $1600 tow of truck and trailer home :oops:
#27 ·
ANYONE who owns a LML should invest in a Insight monitor.
1090446
The green is soot grams. it should build slowly and at about 43, a regen will start.
The red is desired fuel pressure vs actual fuel pressure. If these are not the same, you have fuel system issues.
The teal is EGT at the DPF. Durning a regen, it will read about 1200 degrees.
The yellow is DPF backpressure. Lower is better
