Status
Not open for further replies.
DIY: setting valve lash
5.4K views 1 reply 2 participants last post by  jbrown1132
This is the method i used to set the valve lash.
the intake rocker arm is the shorter of the two. its best to rotate the motor using the bolt on the crank damper bolt. 36mm socket needed to do this
i used the .012" feeler gauge.
First get cylinder No. 1 at TDC (no. 1 is front pass cylinder) on the compression stroke.
at this point you can adjust the following:
cylinder no. 1: intake and exhaust
cylinder no. 2: exhaust
cylinder no. 3: intake
cylinder no. 5: intake
cylinder no. 6: intake
cylinder no. 7: exhaust
cylinder no. 8: exhaust
rotate the the motor one revolution and then adjust the following:
cylinder no. 2: intake
cylinder no. 3: exhaust
cylinder no. 4: intake and exhaust
cylinder no. 5: exhaust
cylinder no. 6: exhaust
cylinder no. 7: intake
cylinder no. 8: intake
hope this helps anyone that has pulled the heads or anyone that has the valve covers off and might want to check clearances.
Save
nice write up nate!
Save
Status
You have insufficient privileges to reply here.
