1 - 7 of 7 Posts
01 LB7 168,000 on what i believe is a stock tranny. Now when im going around 33mph the truck will not shift unless i left off the throttle at just the right moment. If i miss the shift the dash lights come on and it throws a code and it throws it in limp mode. Once i get it to shift it does just fine..my question is the tranny done for? anything i can do to help prolong its life? lol not ready to break the bank yet!
What code is it throwing? P0700 or similar? Sounds like your tranny is on its way out.. Nothing to do now but start saving for a built and put the tuning back to stock and baby it if you want it to last a while
Definitely NOT sent from my iPhone while jumping on a trampoline wearing a banana hammock..
Banned
Sounds like a solenoid issue, what are the codes?
Banned
Clutches are done and material in the VB causing shift failure.
Discussion Starter #6
really it could be something as easy as that?
Banned
That was Mike L. commenting. He is the ultimate Allison Guru, hence the name ML precision converter. Change your fuel filter.........................
1 - 7 of 7 Posts
