My drivers side door has conveniently decided to begin leaking in heavy rains. Can the weatherstriping be replaced and where can I get it.
are you sure its the door? where exacatly is it leaking?
it is leaking across the top just where the door is closest to the top of the windshield
windshield , top of the roof area
Don't know if you have a sunroof but I have seen the drains plug up under the headliner and drip all the way down the pillar. May not be your case, just thought I'd throw that out there. But yes, the door rubbers are replaceable.
Banned
I have heard some ky jelly helps loosen up rubber and helps seal leaks. You should actually be able to take off the rubber and move it around so the bad area is a different place on the door. There is a small section of rubber on the top of the door IIRC. If you need that the dealer should be able to get it :cool:
