1 - 18 of 18 Posts
I installed a tuner on my LMM. Ran it for about 30 mins driving around etc. It died on me now it runs for a bit and shuts off. Does this have something to do with the DPF in the exhaust? If so how do I clean it?? Thanks guys
Slave to the Interwebs
We need to know what kind of tuner you installed and what all is done to your truck. Look in the user CP and fill out your signature. it is a breif description of your truck. It really helps answer some of the preliminary questions
sorry, im a noob.
I ran the XRT from hs performance. I'm an idiot and need to learn what it screwed up. no mods except for a drop in K&N.
Well there is the problem then. Dump the DPF and then see what happens. Is it throwing any codes or a check engine light??
no codes yet, i just need to be re-assured as to why its limping! I'm ready to chop some pipe man!
Duramax Power Levels: Stock, 60hp, 120hp, 180hp
i loaded the mild tune which is 60hp.
I was instructed to 'reset the transmission' on hot so i did that, then loaded the mild tune again. Ya'll guys are so helpful, i really appreciate it! i am quickly learning that its this darn DPF in the exhaust.
Disconnect your batteries for a couple minutes and unbolt the DPF at the flange in front of it. You can run the truck with the exhaust there it will just be a little loud in the cab until you get a delete pipe or whole exhaust.
Discussion Starter · #14 ·
Like I said guys this forum, and all of ya'll are super nice and EXTREMELY knowledgeable. I am very thankful!:drink
Welcome aboard. Hang around you will learn alot here
Discussion Starter · #17 ·
I will definately stick around, you guys are the real deal! I will learn as much as I can. This is awesome info and super quick response time.
I cannot thank enough.
1 - 18 of 18 Posts
