1 - 16 of 16 Posts
Do I install the H&S dpf delete tune before putting the exhaust in? Or do I install the exhaust first? I did some research and saw a guy on here that installed his exhaust first but when I asked a local shop they said install the H&S first.
Thanks
I don't think it makes much of a difference? I installed my exhaust first. But immediately after installed the tune.
did codes pop up?
download the tune first, it will save you having to re-download the tunes to the truck.
Most Known Unknown
i did the exhaust first..
1. installed exhaust
2. got the latest update for the XRT pro
3. updated the firmware to the truck
4. installed tune
as the tuner did its thing, the error codes slowly went away
EGR sensors were unplugged prior to installing the tune
Discussion Starter #6
thanks everyone
Most Known Unknown
on a side note..
make sure your close to your computer, and make sure you have an SD card adapter :thumb
when i installed mine, it gave me some error or whatever, so i thankfully read a thread earlier that day that was from H&S that required me to save some files off the SD card onto the computer and delete them off the SD card, take it out with the XRT Pro and update firmware to the truck, THEN come back to the computer and put those files BACK on the SD card, THEN go back to the truck and install the tune
i got lucky because i was at my cousins house doing the install, and luckily his GF had a SD card adapter for her computer or i would have been asking for a ride to walmart @ 11:00 @ night nono
Discussion Starter #8
Still a little confused about what you just said^^^^ can you find that thread and maybe post it?
Most Known Unknown
Most Known Unknown
Discussion Starter #11
thanks man
Early on, I believe H&S recommended that you install the tune first and run it with the DPF intact for a few miles to make sure everything was going to work properly. Haven't really heard of very many people doing that though. I installed the exhaust first, and everything was fine. The unit will clear any DTCs after it downloads the tune. H&S has exceptional customer service and will help you through any problems.
1 - 16 of 16 Posts
