I have an 06 Duramax. I’m going to be replacing the drivers side restricted exhaust manifold with a BD one here soon. Is it necessary to also replace the up pipe on that side while I’m in there or should it be ok? I know I will need new gaskets for both the up pipe and the manifold, but is there anything else I need to order? Thanks in advance.
Should be fine. New gaskets on each that's it.
I bought one from the dealership new for a 08 duramax cheaper than I could get from a vendor. You could get one out of a junk yard if you can find one
