1 - 20 of 20 Posts
I recieved my Efi Live today and cant recieve my stock information cause its says i dont have the correct drive, it says it cant read cause of the drive, i down loaded the drives from EFILIVE.com but still wont work what do i have to do to solve this problem anyone know what i can do?
What type of programmer do you have on the truck now? i have tried to download some tunes from other tuners and it wont connect if there is a "piggyback" type of tuner. If your computer setup is ok, it will read any type of "flashed" tune. someone help me out here.
· That One Guy
Normally its just Vista that has Driver problems. Does the Flashscan turn on when you plug it into your computer?
· That One Guy
Alright. Did you download the EFILive 8.1 build yet? If not download that and install that and open it up and there is a spot to update Firmware. I was having the same problem last week. The Flashscan needs to be updated.
I Updated the install updates in 8.1 and it said it was sucessfully updated, did i need to have the Flash scan v2 hooked up to computer when i did that
I updated the Install Updates in 8.1, did i need to have the flashscan v2 hooked up when i did that? did i update the right thing never saw Firmware
Discussion Starter · #16 ·
Ok, i did the update in EFILive Scan and Tool (Install Updates) and it sucessfully updated the software, BUT the Flash Scan v2 was not hooked up to computer, so i then hooked it up and did the same thing and it said there are not anymore updates at this time, im lost
· That One Guy
Dang I don't know what else to try without looking at my computer if someone doesn't chime in here I'll check it out tomorrow morning when i get home.
1 - 20 of 20 Posts
