Your lowering your truck right? I think you can remove them. Just check because IIRC one of the blocks is angled to shim the rear end angle. But, you can buy a shim for the rear thats mutch smaller
I installed shackles in mine last summer - lovin' it :rockin.Im putting some drop shackles and just wondering if you have to do something with the block that is under the leaf spring and above the axle? Do you remove it or leave it alone?
Your lowering your truck right? I think you can remove them. Just check because IIRC one of the blocks is angled to shim the rear end angle. But, you can buy a shim for the rear thats mutch smaller![]()
Im loving mine so far!I installed shackles in mine last summer - lovin' it :rockin.
No need to do anything with the block.
Oh heck ya man..... Doesnt everybody?? :helpyou shim your rear end Jason? That doesnt sound too comfortable![]()
