I just had new tires put on my truck and I went with the next size up. I have a 2006 lbz cc long box DRW.....I put on 235/85R16 and the rear wheels ar not touching but there is only like 1/4 inch between them at the bottom. When I hok up my 14,000lb fifth wheel they touch at the bottom and I need to find out about spacers?
What are they?
Where can I get them?
Thanks
Greg
dually spacers
Hi;
I have a 2005 chevy dually and run 235/85r -16 without spacers and pull a 14 000 bumper pull trailer with no problem. What tire pressure are u running?
Sounds like you need to add air pressure.
I am running 80psi as the tires say in them
of course I need valve stem extenders so I can check them more often because they are almost impossible to check with the aluminim rim covers on them
you can find them on ebay. My buddy uses these on two of his trucks with no issues. both trucks are regularly overloaded and he has never had an issue
I got mine from Fred Goeske, and that's the only place I would buy them from.
