1 - 9 of 9 Posts
Are the pins numbered in my ECM so I know which ones to pull or do I just go by the color coding? Tackling in about 30mins and I need to know.
Once you get the ECM cover off and get the ECM out of the way you will need to take the gray cover things off the ECM connectors. Once you do that you need to remove the blue caps on the side that plugs into the ECM. After that you will notice numbers on the back of the connector. You take the dsp pins and shove them in the right number whole. Then reasemble. It's way easier when you start doing it.
There is no pin 69 or 49,WTF? There are only 32 pins on each one,this is on an lb7
yes u need to be on the larger connector.
NewEST Spinny Thinggg
yeah they are on the big plug not the small one
AKA treyfox11
what gives we had a conversation about your tranny a couple of nights ago said it was heating up and now your on to a dsp5 install:confused:
I got the tranny figured out,it was a bad valve like you thought,now I'm getting this stuff hooked up.
1 - 9 of 9 Posts
