1 - 13 of 13 Posts
Well I'm goin for it today in my buddies garage for some heat. Otherwise I have the DSP 2 Switch already in, so i know what I'm doing I guess. Got to practice with that one and its business today haha. Pumped! Any advice on mounting the DSP5 anywhere in these LMM's. I have a few idea's not a big deal but see what you guys thing. Otherwise i'll finally not need to upload any more tunes!
-STOCK (NO DPF ALL THAT JIVE)
-HEAVY TOW W/ TURBO BRAKE
-HOT TOW W/ TURBO BRAKE
-STREET
-HOT
:rockin
THANK YOU JESS @ HUSKER DIESEL!
How "hot" is the hot tune?
not to crazy. I don't have a tranny or antyhing like that but I know its fast. Never dynoed it or tracked yet
nice man!!!
just make sure you disconnect the batteries before pulling the harness off the ecm! you probably already know that but its a mistake i made before and i've done a couple of em so i just figured i would remind you :drink
You think the Hot/tow would be harder on your trans than the hot tune?
heres the spot mine will be goin... theres 2 remote bass knobs there now but i only need one so the dsp will be goin there.
You have any pics of the install??
Thanks for sharing the picture of the install... I am looking for ideas!
I will be installing a dsp5 keylock switch in the spot right above the 2 bass switches. Straight right of the 4x4 switch next to the steering column.
i thought under the dash was good no chance for it to get messed with.
So I did my DSP5 Switch all nice last night. Did a full amsoil service as well as new fuel filter. Also FINALLY modded my wheel well liner for the access panel so I don't have to take it out again for a fuel filter. Truck is awsome! No more ticking I was getting in the motor (i.e. typeriter sound). I dont mind it being its a diesel but its nice that its gone from oil change. Happy with install on my switch. Below is a bad cell phone picture but in time i'll be sure to put some pretty ones up. The knob for the DSP is right behind the blinker lever. Under that is a toggle switch for my strobes (3 per corner :rockin)
Looks good Jim! I put my switch where your rocker switch is, so about the same place. Seems like it they had that spot in mind for switches or something :rof
1 - 13 of 13 Posts
