1 - 20 of 47 Posts
me and my buddy installed DSP5 switches in my LB7 and his LMM and flashed our ECM's. But we both believe they must not be installed correctly because there is not a big difference in our stock tune and our race tunes.. should be a huge difference right??
and i check the voltages with the v2, and the voltages do not change.
either i check with the switch voltage with v2 wrong or we installed the pins wrong.
I swear we installed the LMM pins correctly bc we heard them click into place. and im sure they went in the right holes.
Not sure if i pushed the LB7 pins in far enough tho. :cookoo[1]:
So can i get someone to walk me through exactly how to check the DSP5 switch voltages? Bc i feel really confident the pins are in there right, and hopefully i just am trying to read the switch voltages wrong.
:help
Try grounding the dsp5 switch somewhere else first.
i wanna make sure im checking the voltages correctly before i go back into the ecm.
that'll be my next step though i guess.
I STILL DGAF
If the voltages aren't changing then the switch isn't hooked up right. Make sure pins are in all the way and you have a good ground. Just went through this shit with buddy of mine's LMM.........sucks.
I just feel like im making some dumbass mistake. I push the hell out of the 2 pins and the LMM pins "clicked" into place.
and what do you mean by a good ground? its only those 2 wires that come connected into the switch? i thought it grounds into the ECM? there is no other ground wire right?
I'm That Guy...
LMM is difficult sometimes... Use a needle from the back to push pin in further and ground at battery or under dash.
If you connect you V2, you can check the PID that says DSP program, or something to that effect.
How do you check the switch with the V2?
Sent from my DROIDX
Connect V2 to truck and laptop, open scan tool, select PID called DSP5 Tune and click Monitor RealTime Data. As you switch, it will show the DSP position you are in Non-DSP,1,2,3,4
had kinda the same problem on a lly but same issue.unplug the harness from the ecm and verify they are in the right location probably are.look at the face side of the plug and make sure the terminals are all the way down and you can see them.mine clicked but weren't to the end to make connection.
What is the non-dsp and should it be 1,2,3,4,5 ?
Sent from my DROIDX
The Non-DSP is your base tune and position 1 on the switch, the position 2 on your switch is actually DSP 1, position 3 is DSP 2, position 4 is DSP 3 and position 5 is DSP 4. Don't blame me, I didn't write the program!!! Hope this helps.
Thanks
Sent from my DROIDX
I STILL DGAF
Hence why I said ground the damn thing under your dash or somewhere it'll get a good ground.:drink
That's what I did, then you only have to worry about 1 pin instead of 2!
I STILL DGAF
Amen brotha, those pins are flimsy pieces of shit. (the very reason I grounded under my dash cause I broke one, lol.)
Ha me too!!!
I only ask this question because when I did my brothers lmm I forgot, but did u remove the slide in retainer? Not sure exactly what it's called but u have to slide it out in order to get the pins in all the way.
Discussion Starter #20
thanks for the info. will be getting to the bottom of this starting wednesday when fall break starts :thumb
and duraskank, when grounding the wire, you just clipped then pin off the dsp5ground wire and stripped the wire and put a wire terminal on it? then ground it?
1 - 20 of 47 Posts
