I'm trying to install the PPE boost controller for the LLY and I am not sure how to release tension on the belt to get the A/C compressor off any help would be great. Since the actual pulley faces towards the firewall I dont know if you grab on there or the bolt that faces front on the bracket that holds the tensioner pulley. Thanks!:confused:
Diesel Addict
if you look on the tension pully you will notice there is a place for a 1/2 drive ratchet insert the 1/2 ratchet and go from there..
Found it, Thanks for the help.
