Hello Everyone,
I have been following this forum for a while and I enjoy reading all the information, now it is my turn with issues I guess. Very long post but I tried to cover it all
I have a 2017 Chevy Silverado 2500 HD LTZ with the 6.6 in it. Truck has 80k miles and all stock. I am the second owner of this truck and primarily use it for hauling at work and towing on the weekends. 8,000 pound camper. Truck handles like nothing is behind it.
I started having some issues a few months ago. It seemed every time the truck would go into a regen cycle the check engine light would come on. I never had the code read like a dummy. However it would clear itself after a few miles. Well i started reading forums and one i came across was that these trucks can be sensitive to the type of Def you run. So i changed to Def platinum, before i would just run blue def I always refill when i see its at 20% my truck does not really have a gauge just says ok until i get down to 20%. So i decided to run it down as low as i could before switching over to the platinum blue def. That is when the problem started, i believe I was at 10% and the Def light and check engine lights came on I thought well that's because it is low, the truck went into limp mode 65 Mph max for 100 miles or something. I filled the tank when i got home and the light and warning went away a day or so later. I thought problem solved and it did for a while. I took my truck in for service oil change and fuel filter, when i picked up the truck the def light was on again and it was in limp mode. The place that changed the filters said they tried to clear it and the code would not clear.
Fast forward to now, i have been looking at all the forums and tech pages all i can find for this code is Lost communication, I checked voltage on each plug terminal and i have power and ground so i thought i was good and the sensor was bad, i changed the NOX sensor and pigtail plug as one terminal looked funny. Took truck to the shop hooked it up to the Snap on machine and went through the re lean for the new sensor and it still will not let us clear the code and still in limp mode and same code.
I looked again for new info and what i found is the pins inside the plug to the Nox Sensor should have certain voltage, so i tested each of mine. Plug has 6 wires, Here are the results. Ground good, Power 12.6V, Then 4 other wires on the sensor, 3 of the 4 read between 2.8V - 3.5 V. The 6th Wire reads 1.8 Volts I thought that was weird so i traced it and didn't find any shorts or marks on the wire, that wire goes to the fuel pump driver control module. No codes came up for that module at the time. However after doing some testing and playing around i had a code of U18A2 pop up which is for that Module not communicating. The scanner let me clear the code which I did. However the original Code of U29E remains.
After all of that very long description my question is has anyone else run into this? I thought maybe the Fuel pump module is failing and that's why i am only getting 1.8 V from it. However i dont want to just start changing random expensive parts if i dont know the root cause of the problem. That module is 300 bucks from what i have found and it has to be programed?
Anyone have similar issues? I am at 25 Miles until 5 Mph so truck is currently parked and not making any money.
