Duramax Fluid Capacities / Torque Specs
62585 Views 0 Replies 1 Participant Last post by  tgreene
Alright I know this contains a lot of extra imformation and also covers the gasser trucks as well but I thought it was all good info. As far as MAG-HYTEC trans pans its brings the total capacity to 10 1/2 qts, the ally deep pan brings the total to about 10 qts as well, the rear diff cover brings the total to 8 qts.
01 - 04 LB7
Engine, with filter..........10.1 quarts
Cooling System, AT Initial Fill..........20.3 quarts
Cooling System, MT Initial Fill..........20.8 quarts
Automatic Transmission, 4L80-E Initial Fill..........7.8 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts
Automatic Transmission, Total Fill
4 speed 4L80-E..........13.6 quarts
5 speed 1000..........12.7 quarts
Manual Transmission, ZF S6-650..........12.7 pints
Manual Transmission, NV4500 (TOPC)..........7.9 pints
Differential, 8.25 RingGear Amer Front..........3.6 pints
Differential, American 9.25 R Front..........3.6 pints
Differential, With 10.5 RingGear Amer Rear..........5.5 pints
Differential, With 11 RingGear Dana Rear..........8.5 pints
Differential, With 11.5 RingGear Rear..........7.7 pints
Differential, With 8.5 RingGear Amer Rear..........4.9 pints
Differential, With 8.6 RingGear Amer Rear..........4.9 pints
Differential, With 9.5 RingGear Amer Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........6 pints
Transfer Case, BW1370/4401..........3.2 pints
Transfer Case, NP241/243..........4.5 pints
Transfer Case, NV236/246..........4.1 pints
Transfer Case, NV261/263..........4.1 pints
Transfer Case, NV149..........4.9 pints
TORQUES:
Oil Drain Plug.....62 ft/lbs
Manual Transmission NV4500 Hex Head
Fill Plug 30 ft/lbs
Drain Plug 27 ft/lbs
Manual Transmission NV4500 SQH
Fill Plug 30 ft/lbs
Drain Plug 30 ft/lbs
Manual Transmission ZF S6-650
Fill Plug 26 ft/lbs
Drain Plug 26 ft/lbs
Transfer Case NV236,246
Fill Plug 15 ft/lbs
Drain Plug 15 ft/lbs
Transfer Case Others
Fill Plug 35 ft/lbs
Drain Plug 35 ft/lbs
04.5 - 06 LLY
Cooling System, Initial Fill..........24.4 quarts
Differential, With 10.50 RingGear Rear..........5.5 pints
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 11.50 RingGear Rear..........6.4 pints
Differential, With 8.6 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Transfer Case, NVG 149-NP3..........4.5 pints
Transfer Case, NVG 246-NP8..........4.1 pints
Transfer Case, NVG 261-NP2..........4.1 pints
Transfer Case, NVG 263-NP1..........4.1 pints
TORQUES:
Fill Plug 27 ft/lbs
Fill Plug 26 ft/lbs
Transfer Case NVG263-NP1
Fill Plug 15 ft/lbs
Transfer Case NVG261-NP2
Fill Plug 15 ft/lbs
Transfer Case NVG246-NP8
Fill Plug 15 ft/lbs
Transfer Case NVG149-NP3
Fill Plug 15 ft/lbs
06 LLY, 06 - 07 LBZ
Cooling System, Initial Fill..........25.4 quarts
6 speed 1000..........12.7 quarts
Manual Transmission, 2WD NV4500..........8.1 pints
TORQUES:
Fill Plug 27 ft/lbs
Fill Plug 15 ft/lbs
Fill Plug 15 ft/lbs
Fill Plug 15 ft/lbs
Fill Plug 15 ft/lbs
07.5 - Current LMM
Cooling System, Initial Fill..........24.8 quarts
Automatic Transmission, 6L90 Initial Fill..........6.4 quarts
6 speed 6L90..........12.4 quarts
Transfer Case, MP 3023/3024..........3.2 pints
Transfer Case, MP1222/1225..........3.2 pints
Transfer Case, MP1226..........3.2 pints
Transfer Case, MP 1625/1626..........3.2 pints
TORQUES:
Transfer Case BW4485NR3
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
Fill Plug 13 ft/lbs
Drain Plug 13 ft/lbs
See less See more
Reactions: 1
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
