1 - 7 of 7 Posts
What are you using to make the dash pod stick to your dash. I have the luxury dash pod and it will not stick. I have cleaned the dash very well. Tried heavy duty velcro, 3m double sided tape, nothing seems to stick well enough.
IB4X4N
Same problem
Mine is the same..... Think I'll try clear silicone when I get around to it. Take module out and put a dollop inside at each corner maybe. Put something on it over night to hold till it sets up. Wedge a balloon or football on it can't hurt.
Good idea might try that too. Mine is fixing to come out to hook up the EGT probe and back up camera.
Gorilla glue. All you need is a small amount.
I have thought about a more permanent solution like that but what if you want to take it out one day? Will the gorilla glue clean off good enough?
Ive removed my dash pod once, since ive Gorilla glued it 3-4 months ago. I used a very small amount. By small I mean just a drop. Hardest part was removing it. I was able to remove the dried up heavy part. It left a stain of where the glue was, but to me the stain isnt noticeable.
I used the supplied 3m velcro strips. I had to heat up the dash a bit for the adhesive to actually stick. Still didn't stick as well as I'd hoped but once I got the weight of the cts and the dash trim back on it seems to stay put just fine. Little bit of play in it if I really mash on the buttons but it doesn't bounce around while I drive.
1 - 7 of 7 Posts
