Specs:
2005 GMC Duramax 2500HD
Edge Juice w/ attitude
Modified air filter box w/ K&N
EGR Blocker Plate
Everything else is stock
I've been having problems with the juice w/ attitude. It seems as if the truck doesn't have any power. I jump in my brother-in-laws cummins with a smarty jr. chip set at 70hp and it blows my d-max out of the water even on with the edge on setting 5. Aside from not having much power, there are times where the truck sputters when I'm driving and the check engine light comes on. This usually happens when I get on the throttle a little bit. Thats the biggest problem and the best way to describe it is the truck reacts the same way as if my fuel is gelled up. With time, the truck starts running normally and the check engine light goes away. I'm not sure if I've got hidden codes, lift pump problem, or if its just the juice w/ attitude. I'm probably going to take it out soon and see what happens but I just want to know if anyone has had a similar problem. Please help I don't want to screw up my truck.
EGR Blocker Plate
