Anybody have a picture of where the two pins from the DSP 5 are placed in the ECM, and do the pins actually plug into the ecm?
In the help menu there is a tutorial that will show you where to install the pins, along with instructions. That should be all you need to get it done. Just be sure to orient the ECM plug correctly like the picture so that you put the pins in the right spot.
Ok ill check that out Thanks
