i just got my efi live 2 weeks ago, now when im driving my abs and alert light comes on and the message board says "service brake system" everything still works as it did as far as i can tell. it triggers randomly after a bit of driving. so my question is has anyone had this problem with the tuning or know what i can check? fluid is good, wires are good, pads calipers etc etc are good :help
It could be the tire size or speed limiter parameters throwing the light, I see you have 37" tires, that'll do it!
Do you have the edge insight?
I'm That Guy...
Call up Rob or Dustin.
Someone told me EFI can only calibrate up to a 35" tire, I had the same issue with an LMM truck, had 38.5" tires on it, so I adjusted the tire size accordingly and it had all those lights until I used 315-75-17 as the size and no lights. Speedo is off by a little but he has to deal with it, Can the GM TechII solve that issue?
Discussion Starter #6
i got my efi through Armor inc. up here in red deer AB. he deals through rob. i talked to him today hes going to look into it for me, ill check abs sensor as well. it never had a problem running 37s before i got the tuning so i dont think it would be the tires?
