1 - 19 of 19 Posts
2008 Chevy 3500 installed EFI live tune now on every start you have to stay in throttle to clear out then runs good until next start any ideas or help would be appreciated
Super Moderator
2017 GMC Denali 2500HD, 3.5" Rough Country Lift, 305/55R20 Yokohama Geolandar A/T
Who wrote the tune? Did the condition exist before installing the new tune? Does it still exist if you put the tune back to stock programming?
If the condition started after you loaded the tune, and goes away when you go back to stock programming, then your tune needs work.
The first step would be to contact whomever you received EFI live stuff from.
Reactions: Melonhead1102
Condition did not exist before tune EFI live wrote the tune in with the V3 once you install it it deletes all other tunes can’t go back to stock
Someone else got burned on that recently. Make sure your save your tune first before you do anything else.
your supposed to save t
You are to save the stock tunes before you upload new
EFI live does not write tunes, it is a program that allows this to be done. You need to go back to where you purchased the stuff and have them fix it.
Need to talk to your tuner where you got it. Let them know the issues and they'll adjust the tune accordingly if need. And x2, always save your stock tune! You can get it bench flashed at a dealer for reasonable to put it back to stock though. Then next time you read it, download your current tune and save it a few different places.
Hey Pal we don't talk about deletes. So move along
1 - 19 of 19 Posts
