p0113 intake air sensor high voltage
p0183 fuel Temperature Sensor Circuit High Voltage
p2564 Turbocharger boost control position sensor ciruit low voltage
p0090 fuel press regulator circuit
p0193 Fuel Rail Pressure Sensor Circuit High Input
p2610 Control Module Ignition On Timer Performance
p2510 Engine Control Module Relay Circuit
I bought a pre set ECM with the DSP 5 switch I hooked everything as instructed when I went to start my truck at first would'nt start after a few trys she fired up with check engine light on first time for this truck I put her through hell no problems I am confused
Thanks I was thinking about doing that his tunes are great from what I read maybe my truck had the problems from the stack I had the truck is holding back with the new ECM I dont know what to think I just want my truck to have action like you guys!
vinny you know your truck should be on the otherside of that big white thing we call a garage door with the bumpers on it and the motor in it man some one has to show you were you park duramaxs have luck fixing it sad thing to see a d-max down
o its had a treat this week. It got to sit in the shop while i tore the interior apart. Otherwise it has been sitting in our machine shed since august. Someday ill put it back together, no rush though. Pulling season doesnt start till may.
Do the codes come back when cleared?... Mine had a bunch of codes once because I had turned the key on when wire harness was disconnected. Flags flew because of all the disconnected stuff the computer could not see. I reconnected everything; cleared the codes and the chk eng light stayed out.
