1 - 13 of 13 Posts
Just installed the all season 3 inch bridge, I made my own egr riser plate from 1/8th inch flat steel, I ran the truck and got a p0299 turbo underboost code. That is the only code I get, I noticed that the gasket for my riser cap hangs out a bit, any thoughts? Is there a way to check the blocker plate for leaks?
Sent from my Zio using AutoGuide App
Discussion Starter · #2 ·
Anybody had this code?? P0299??
I was looking around my up pipe and can't see any soot and there's no whistle, guess I hafta make a leak tester for my bridge and check the o-rings
does your tune have the egr turned off and setup right? I had same code on my truck when i just turned EGR off in tune w/o changing anything else
Not sure I'm running a duramax tuner tune, got it when I had just the blocker plate in, the scan tool I used also had an egr code but it said performance closed
What do you mean by changing anything else? What should I look for?
I agree with Dustin, your EGR cap is probabaly leaking. Remove it, clean all mating surfaces with brake cleaner and reseal with high temp silicone (orange stuff). I hope you made a cap that attaches to the block where the cooler did too (see pic) or you may have a hole in your up pipe too.
Well found out my map sensor was broke off and the o rings on the bridge are bad smh. So I ordered up some new o rings gonna install it right this time, heavy sighs. And yes I made sure to bolt my cap to the cooler mount, I heard they like to break uppipe bellows :)
Glad you figured out your issue.
I get too excited when new parts come in and I start cutting corners my own damn fault!
They now have two support holes. :)
So, what does the new one look like?
I ordered mine from you in September, but have yet to pick it up and wasn't sure if I would have the new design or not.
1 - 13 of 13 Posts
