1 - 20 of 38 Posts
Well the Egr hose split on me yesterday. Its the tiny one that sits in the center of the engine. My question is can I just get some radiator hose and cut to length. Does anybody know the size? Please help me out, hate it when my truck sits...lol
Any 5/8" hose will work, don't need a pre-bent one. Its a straight shot, make sure it's cut to the correct length and you won't have any issues. Had mine blow out too, made quite the mess. While you are replacing, you should swap out the O-Ring on the thermostat bypass to the EGR cooler, they tend to get brittle with age.
Its a slight upwards shot with the cooler in place. 5/8" radiator hose is flexible enough not to kink. Had to replace this hose before my egr suddenly fell off.
Discussion Starter #7
Would that be the o-ring (110) in the diagram above. What kind of pliers did you use to get those clamps off? The one I can probably get to but the other looks like a pain. Im going to start to take it off this afternoon.
Discussion Starter #9
Got to give the hose credit..lasted 9 years on my truck. lol
Discussion Starter #12
worm clamps?
Discussion Starter #13
LHN...We ARE the Joneses
Y'all are talkin' 'bout two different hoses. The OP has a prob with item 107 in the exploded pic, not item 746 with the sharp bend. nono
OP, after you remove the intake tube above, just remove the whole 90EL (item 9) tube from the thermo housing, with the blown hose on it. R&R the short length of hose (& funky clamps) AND plan on replacing the 'O' ring when you re-install the complete tube/hose.
Long reach pliers will get you access to the hose clamps,
16" Long Reach Pliers Set
But the movement/stress you'll place on the tube, it will probably trash the 'O' ring in the process. Just plan on removing it.
As for using bulk on Item 746, yes it will kink if you try and match the same length. Extend the replacement length and the curve/bend won't collapse.
worm clamps?
regular screw clamps, use a 'worm' gear to tighten.
Reactions: biketopia
Thank you!!!
Discussion Starter #16 (Edited)
Now you say take the one end off and then take the pipe with the hose out of the thermostat housing. Can I do that with the intercooler cast pipe in place?
Yes, the tube just goes under the EGR manifold.
Remove the bolt (#11) to the right of the alternator, and the bolt (#2) behind the alternator. If you pull the plastic intake tube, the single spring clamp/hose at the EGR cooler is accessible from the top.
Yes you can. It's a pain in the butt. Unbolt the aluminum 90 thermostat bypass, remove clamp from the egr cooler side, pull the aluminum 90 out of the hole and pull it and the hose out together. Cut similar length hose, clamp the hose to the 90, push back in and connect to egr cooler, bolt aluminum 90 down.
Discussion Starter #19
ok I just tried it at my lunch and I have to come back tomorrow to finish. Bolt 11 I needed a longer extension. But I did get the clamp off where the hose meets the egr. Should have this fix tomorrow. Thanks for all the help. Oh one thing, How much coolant do I need to fill this back up?
Depends on how long you ran it. Mine was run for 5 minutes pouring out, took 2 gallons.
1 - 20 of 38 Posts
