Can I turn off the EGR with my Diablo with out putting in the blocker? If so What inprovements will I have?
Received a Hummer
I don't know if Diablo can shut the EGR off....someone else will have to take that one...but I can tell you that all the EGR does is stop soot from going back in...it's just a $12.00 metal plate.
Administrator
I believe if you are running v2.02 you can...if not, then no.
Yes it is the 2.02 Do I still need the blocker plate & what is the benfits?
The Diablo Predator does not disable the egr. It only disables the diagnostic that creates the maf codes when you modify egr flow.
Disabling the EGR is a Clean Air Act offense with fines, FWIW.
Blocking the egr has no performance benefit, though it may help prevent intake restriction over time
