1 - 9 of 9 Posts
Yesterday while driving around town after getting up to Big Bear Lake. My check engine light came on with Service Emissions System on the DIC. And it also said 175 miles till 65 MPH max. Has anyone had this. My truck just rolled over to 5500 miles. I called my service tech and said to add DEF fluid and drive around. And still on. Has anyone had this issues????
If it's because of 'low def' the message would be 'Exhaust Fluid Low', not 'service emissions'.
Yea I figured as much. I’ve read on some items that it could be the DEF filter causing that issue. Just seeing if this has happened to other people and see their fix
I have had the same issue at 10K km. Brought it to my local dealer and they replaced my ECM, which wasn't the issue as it went into limp mode again right away. So I went to a different dealer and they replaced the Nox 2 sensor. Been 6 months since, no issues. Also it seemed my truck was in regen alot, since the sensor the regens are almost un-noticable. My truck works awesome, very happy with it :grin2:
So guys I took my truck to get checked out at my local dealership and of course as soon as I get there my check engine light goes off. The DTC was stored as p206b. It seems like some aeration occurred who he’d caused the code to be thrown. There was no power loss. Just message giving me 175miles till 65mph limit. Everything checked out at the dealership. Hopefully the last time this happens
Had the same issues on my truck, same code in fact. Lost my truck for just over 3 weeks before the issues were sorted out. Even had it back before it went back into limp mode, and it didn't actually reset the miles to limp mode. Just a heads up on that. You maybe driving along and your truck may go into limp mode.
Same happened to mine now but earlier in week my check engine light came on when it was trying to clean the dpf filter but the light turned off now it says I have 145miles intil 65mph max i also pull a gooseneck trailer with mine and I have about 80k on the clock
1 - 9 of 9 Posts
