We regularly go up and down a steep mountain road. Our 2011 truck used to make no noise going downhill with the engine brake on, you could just feel it slowing the truck down. Now it makes a rumbling sound which appears to be coming from the top of the engine. If I turn the engine brake off no noise. I guess the turbo is the engine brake? Any ideas?
Possibly a vanes stuck?
Do you have a monitor so you can see your vane position while driving and when Turbo Brake activates? If you do when it first activates vanes should go to 100% and then decrease til the truck downshifts then it goes back to 100% in the lower gear and repeats the process.
Turbo Brake. Turbo Vane actions use the engine compression to slow.
I would look for an exhaust leak, perhaps one of the bellows on one of the up pipes has cracked, or a problem with one of their gaskets leaking.
