Administrator
Thanks to 05_LLY
8th Vin #1-LB7 300 hp
8th Vin #2-04.5-05 LLY 310hp autos only, 300 hp manual trans and 4500/5500
8th Vin #3-06 LLY ratings are the same as vin 2
8th vin #D-LBZ 360 hp auto only, not an option in manual trans or 4500/5500 trucks>
8th Vin #6-LMM 365 hp
Thanks to 05_LLY
I'm not sure if I get this, pardon my ignorance. I'm trying to decipher a vin on a model year 2006 truck.
The 8th digit is a "2" which, if the quote above is correct, would mean that this truck doesn't have the 2006 LLY engine, which 2006 LLY engine is supposed to be closer to the LBZ.
Also this 2006 VIN "2" truck is mated to the manual shift 6 speed Allison, which I have also read indicates that we are talking about a "2006 LLY" which is closer to the LBZ engine.
And if all of this is true, then in the 2006 model year, there were 3 engine options:
- VIN "2" - "LLY" - Like an 04.5 - 05 LLY
- VIN "3" - "06 LLY" - Major changes to the LLY, same internals as the LBZ - better than the VIN "2"
- VIN "D" - 06 "LBZ"
Wikipedia says that the 06 LLY (the LBZ-like LLY) is a VIN 2. More specifically, it seems to contradict the VIN 3 Code above:
"The 2006 LLY (engine code "2") debuted in the beginning of 2006 and ended production with the start of the 2007 calendar year. Mechanically it is identical to the LBZ and is mated to the new 6 speed Allison transmission however it retained the LLY designation. Its output is 310 hp (231 kW) at 3200 rpm and torque is 605 lb·ft (820 N·m) at 1600 rpm. Huge changes were made for the 06 LLY"
Duramax V8 engine - Wikipedia, the free encyclopedia
Anyhow, I want the LLY that's like the LBZ. The truck I am about to buy has a VIN "2" and the manual shift 6 speed Allison. With all this conflicting information, which engine do you think is in this truck. I've seen 2006 GMC and Chev Diesels with Vin 2, and D. But never a VIN 3.... searched the VIN Check section too. Never a VIN 3.
If the VIN 2 is the 04.5-05 style LLY, then it looks like there were 3engine options in 2006, and all 3 were mated to the 6 speed manual shift Allison.
When I add up three factors:
1. Wikipedia says the 06 LLY has a VIN 2 (never references any VIN 3 as above);
2. Wikipedia and others say the 06 LLY is mated to the 6 speed Allison Auto (manual shift) - which is what the vin 2 truck I'm looking at has;
3. Existence of a VIN 3 would mean there were 3 different engines in model year 2006 - a vin 2, a vin 3 and a vin D. Never heard that there were 3 different engines in MY2006; and
4. Searched the VIN check section and internet, never seen a VIN 3 engine code;​
......they all add up to the thought that "VIN 3" quoted above for the 06 LLY (that's mechanically identical to the LBZ) is an error.
I want the 06 LLY because the internals are better and the overheating issues are solved. The mystery is whether there is any such thing as a VIN 3. Any help is appreciated!
Anybody ever seen an '06 with a VIN 3?
I think I figured this out.
VIN "3" engine code is for the 06 Hummer Alpha with the 06 LLY engine. Had to find this on an oil filter cross reference site. Same site shows only VIN 2 and VIN D for the GMC/Chevy trucks for 2006.
Administrator
Discussion Starter #4 (Edited)
This was just a repost from another member that wasnt a moderator at the time (i think), but you are correct with the information. I looked it up on dieselpowermag.com. But it also looks like you answered your own question...so there is a vin code 3 that is an LLY, just not in a silverado or sierra.
I know, I know, thread from the dead, but at least this is a sticky anyways. I really can't seem to figure out why this is such a mystery to everyone. I'll spell it out in very simple terms. The 06LLY IS NOT and lly (04.5-05) it is the LBZ with a 310hp tune. Every, I meant EVERY part on an 06LLY is identical to an LBZ. In fact, if you have an 06 LLY you can have the dealer upgrade you to the LBZ power level with a flash. Simple as that. Now you may be wondering, "how do I know if I have an 06LLY?" Other than the Vin code you can look at the shifter. If it is a Tap Shift 6 speed, (its NOT a manual shift auto) you have either an 06LLY or an LBZ.
To quote.. "thread from the dead" sorry!
Just curious if anyone has ever actually gotten a dealer to flash their 06 LLY with Allison 6 speed tap shift (de-tuned LBZ) to the LBZ tune.
My stealer "service" department basically told me I was an idiot for even asking such a question. I asked if there might be someone else in the department who I could speak with about it.. was told they weren't interested in even considering it.. basically rudely dismissed.
They are the only dealer near me listed as a performance dealer on the Chevrolet website. I may or may not call back and just ask to speak with anyone but the person I spoke with before..
Actually bought this truck used from a dealer about 2.5 hours away.. might reach out to them and see what they say.
Probably won't be doing any future business with my local dealer.. fortunately there are 5 other GM dealers within 30 minutes of where I live.
Anyway, if you've been able to convince your dealer to flash your 06 LLY to an LBZ tune.. mind letting me know how that went? Thanks in advance!
Sent from my moto z4 using Tapatalk
