Confirmed Fix Details
Tech Reported Fix Details
Confirmed Fix
1 TROUTWINE1
September 12, 2013
2008 Chevrolet Silverado 3500 HD, LTZ 6.6L, V8, Diesel, Asp T, VIN 6, Des LMM, 32V, USA *
Battery Ground Cable
- Measured voltage drop on cables. important to remove starter relay fuse to get a extended crank of 5-10 seconds. Use a min max meter and record voltage drops. Anything over .250 volts is bad. Found worst spot at .864 volts at connection of RH battery negative post connector and cable crimp.
Repaired Battery Ground Cable
2 DJAutomotive3
August 12, 2013
2010 Chevrolet Silverado 3500 HD, LT 6.6L, V8, Diesel, Asp T, VIN 6, Des LMM, 32V, USA *
- Battery Ground Cable
Replaced Battery Ground Cable
3 Tech
January 8, 2013
2008 Chevrolet Silverado 2500 HD, Wt 6.6L, V8, Diesel, Asp T, VIN 6, Des LMM, 32V, USA *
121,327 miles Replaced Battery Ground Cable
1 Jason Stein
December 5, 2013
2008 Chevrolet Silverado 2500 HD, LT 6.6L, V8, Diesel, Asp T, VIN 6, Des LMM, 32V, USA *
Both Batteries
- replaced both batteries,failed when tested
Replaced Both Batteries
1 David Maze
January 7, 2014
2009 Chevrolet Silverado 2500 HD, LTZ 6.6L, V8, Diesel, Asp T, VIN 6, Des LMM, 32V, USA *
Engine Block Ground(s)
- bad grond
Repaired Engine Block Ground(s)
I searched a site and seems there are a lot of problems with loose/bad grounds even at the actual crimp at the battery cable. and a few problems on the positive cable side. deff a bad conncetion and when you move the cables it resolves itself until it vibrates loose. check all connections and do the wiggle test wiggle things trying to get it to act up again. if nothing is found ohm all the grounds. there is a TSB out about some fuses loose in the underhood panel check and make sure they are all tight.
