I have an 08 lmm and over the weekend the engine started to make a whistle/whine sound separate of the turbo whistle. It starts almost exactly at 2000rpm and continues after 2000rpm. When I let off the throttle it stops. I tried listening for it in park and it does not make the sound. Also if I manually down shift to get into the 2000rpm range it does not make a sound either. I checked the turbo shaft play on the compressor side and it has a very small amount of up and down movement but I don’t think it’s enough to be making contact. It also doesn’t matter if the engine is hot or cold.
Just something you can check quick the Serpentine belt idlers were going on mine and made similar noise.
I will try and do that tonight. I don’t think that is it since it doesn’t make a sound at idle or in park reved up to 2000.
