Im trying to tune my truck following all the steps (unplugging radio fuse, ignition on and truck is not running) when i goto flash the truck pops up with service 4wd so it takes a couple min goes away so proceed and then i get a $0281 code. Anyone know what im doing wrong? TIA
2005 LLY
Discussion Starter · #2 ·
Also i seen alot of people get it due to outdated firmware but i just got the autocal in the mail. Would they send me it outdated?
Possibly, also most recommend that a low amp battery charge be applied to the batteries while programming.
Even with getting a new AutoCal there’s a good chance you’ll need to first update it.
EFI makes changes once in a while, when the tune was done they probably had a update in the works.
Your batteries need to be above 12 volts when loading tunes with any tuning device.
After having loading issues in the past I now always hook up a battery charger, setting it on float charge or even 6 amp or what ever your charger has for a little lower charge.
You’ll find the tunes load faster when the voltage is around 12.3-12.5.
As soon as you turn the key on the volts can drop in the 10-11 volt range, grid heater and glow plug circuit will take them down.
Even the dealer will hook up a battery charger when they’re checking for updates
I picked up cig lighter/power plug digital volt meter, so I can monitor the voltage while loading tunes.
This one I wired directly to the driver side battery, but your factory power socket will do the same.
