1 - 15 of 15 Posts
Ok, so I bought this truck recently, lot of work went into it, but it was never dynoed. Here's the list
ARP studs
Engine breather kit
20% injectors
83mm borgwarner turbo
4" down into 5" exhaust
5" SDP intake
100hp tune
CP3 fuel pump
FASS 150 fuel system
Sun coast stage 3 transmission
no idea what the power would be and nearest dyno to me is over 2 hours away. Just curious if maybe you comp guys might have a better idea?
83mm in a compound or single? I'd say mid to high 500s. Maybe maybe maybe maybe low 6s. Take it to the track run it and then plug that in to the calculator on competition diesels site or dd
ARP studs
Engine breather kit
20% injectors
5" SDP intake
100hp tune
CP3 fuel pump
Can you be more spexific on the specs of the turbo. Stock cp3? New? Who's injectors?
Sent from my VS988 using Tapatalk
It is a single turbo, forgot to mention that, so there is a bit of lag getting her going...but I'm never going to own a gas truck ever again after this
I was going to say 500's as well but need more info.
Yes I love big singles! Haha. Need to throw more fuel at that thing. I'd go at least 60 or 100 and leave the stock cp3 as your limiter for now depending on what year motor you have pistons or rods will be the thing to worry about. Stock cp3 should do low to mid 600s. What converter do you have and what's the specs on the charger? Whose doing the tuning? I would have them change the shift points for the transmission, and the speed the converter locks up at when cruising so it's easier to stay ontop the charger.
I agree, I had blake bump up the rpm to hell stay on top of my 72mm and its not that laggy at all.. 100 overs are like 60's now Nic. Lol. Do 150s at least.
100 overs will still do 9 to 1k depending on cp3s lol. Some of yall are getting injector happy lol. That 83 would love some 200s though and dual pumps. Rods and pistons wont theough lol
Yeah your right Nic, just seeing how much money I can get him to spend Lmao.
Oh well if were doing that then it needs every part wagler or SoCal can fit in the fed ex truck
^still not big enough lol
Theres a turbine powered mini van I've seen somewhere before in YouTube.
Discussion Starter #15
Well for now this is my daily driver so I'm not trying to go crazy just yet. My buddy who I got the truck from is in the navy, hes on a sub some where so it'll be a while before I get the trans specs other than the build receipt. It was tuned and built at a diesel shop in Danville, CT. And the cp3 is not stock but I don't know what exactly was put in, I'll get the details soon hopefully
1 - 15 of 15 Posts
