:help Excessive pressure from the oil filler cap and pcv tube, enough to blow the cap off if I loosen it, and purplish/grey smoke, the kind that makes me want to fill the side of the truck full of chevron stickers and the box full of dead fish and birds. I look like such a planet killer when I stop at a light, it really pours out from both the exhaust and pcv tube. First thought, injectors! Well, I had the injectors tested, twice (and gm said they were replaced 2006), then had the compression tested. The garage stopped at the 4th cylinder because they broke all the glow plugs, but they said the #1 cylinder was 40psi and the others were 400psi. I'm not certain as to how competent they were with diesels, but he did know way more than I do. The truck has 190,000 Kilometers (115,000 miles), has tons of power, doesn't add or burn oil (as far as I can tell), oil doesn't smell, turbo blades are clean and tight, air filter is clean! It takes about twice the fuel it did before the smoking started, which is about a month after I bought it (about 5 months ago). I have no choice but to keep driving it, being my only vehicle. I want to fix it, please help!! Anyone heard of this problem? Anything I could try before having a rebuild, or is this really it for my truck? Thanks:help
