1 - 11 of 11 Posts
will a new cat back system let out more smoke
Hi, I'm Earth. Have we met?
Not with out adding a programer of some sort, gotta give it more fuel to get er to smoke.
so if i got a programmer it would smoke more?
Diesel Addict
depending how much hp you add for instance a 80hp tune will cause very little smoke but a 150hp tune will make some smoke worth seeing..
Yeah smoke usually comes with tranny trashing power. The predator tunes smoke pretty good!!
Discussion Starter #6
isnt it bad for your truck when you run those programmers on the really high settings if your truck is basically stock
Diesel Addict
it's not so bad for your truck as it is for your tranny:D:fart
Discussion Starter #8
ya thats what i thoght, so if i plan on running on a high setting at all i need to upgrade my tranny
Diesel Addict
if you keep the WOT in the highers to a minumim you can run for a long time with 380rwhp to 400rwhp but anything over that you will run ito the red zone ratherly quickly..
Discussion Starter #11
what is WOT
1 - 11 of 11 Posts
