yeah F that crap.THere is no true turbo back system for a dmax un less you change turbos. YOu can either get a cat back or a front pipe back(turbo back). I recomend a Mbrp system, you cant beat them, good quality and great fit!
TTS power systems makes a tru turbo back set up for the stock turbo, but plan on $600+ for just the down pipe and front pipe![]()
Not a whole lot of difference....straight pipe got real loud in the cab around 2200 RPMs. The 4" MBRP with muffler is a little mellower, but there is a resonance in the cab all the time. Straight pipe was only a little louder than stock while cruising at about 2000 RPMs (about 70 mph for me).But would there be a difference from the strait pipe to 4" if you were towing?
Loosing the cat in your case will be a huge egt improverment 4'' even more since you are running a bigger program!But would there be a difference from the strait pipe to 4" if you were towing?
ill check it out.......ive looked at the MBRP but ill look at AFE too.04LB7,
Check out the AFE or MBRP systems, we stock them both and they are the best value going for fit finish and options like cat back, front pipe back etc etc. Call us and we'll be glad to help you on them.
Mark @ DPPI
Thanks for the info on loosing the cat. I won't be running the big program while towing and will still probably run 4" when I get the money to do so. you had asked if the Bully Dog read DTC's, yes it does. If I had to do all this all over again I think I would go with EFI live because of the almost unlimited programming possibilities. The BD was a good one for updates and all but there is no forum for help.Loosing the cat in your case will be a huge egt improverment 4'' even more since you are running a bigger program!
We know, us LLY guys like people like you that sell your stock systemthere is no cat on my truck. came like that from chevy
We know, us LLY guys like people like you that sell your stock system![]()
Your front pipe is worth about 40$ id sell it.I still have my stock strait pipe system if anybody close would want it. Id give it away. Its for ext. cab short bed
