A couple of things,
if you are not an Experienced Diesel Technician PLEASE DO NOT respond to this thread I need real help, I sorry if this offends you.
If you are using an Acronym please do so like this eg; FICM (Fuel injection control module) I'm not a mechanic and do not know what most of them are reffering to.
Second I apologise for being so long winded.
The first time this happened was 2 years ago. Coming back from a golf trip. I was in a hurry and pushing the truck pretty hard about 95mph to 100mph. All of a sudden it fell on its face, started chugging and I couldn’t get more than 2000 rpm out of it. It went into limp mode, I guess. After pulling over and letting it sit for a few minutes it cleared up.
Last winter it happened again. This time it was a couple of things going on. I was out in Alberta and it got down to -30C. The truck wouldn’t start even after being plugged in overnight. It seemed like it wasn’t getting any fuel, (just cranking over and not firing) so I primed the fuel filter pump, and it fired right up.
Then on a fishing trip up into the mountains around here it happened again. It fell on its face and I couldn’t get any power when I stepped on the accelerator and couldn’t get more than 2000 rpm.
So I pulled over and primed the pump again, this seemed to clear it up. It happened several more times and each time it was around -15C. Thinking that the pump was losing prime because it was sucking in air, we changed the o-rings on the pump, again this seemed to do the trick.
I have learnt that it needs a new glow plug module. (the second part of the problem)
Last week like a fool I ran out of fuel. After putting some fuel in the truck and priming the pump it fired up. I took it down and fuelled it up.
The next morning I drove into my shop and it seemed fine, but after I hooked onto my haul trailer and got down the road a few miles it started doing it again. Thinking I didn’t bleed all the air out I primed the pump again. It didn’t work this time and I took the truck back and unhooked the trailer.
Now this is what has been done since then.
Fuel filter changed – Twice - the second shop changed it after I already did!!!
Codes reset and injectors bled (So they say) The injectors didn’t look like they had been touched so I it took it to another shop.
This shop tried a FICM (Fuel injection control module) That didn’t work
Then he tried a ECM (engine control module) that didn’t work
Also this is one code he pulled off the truck; P1093, Fuel Rail Pressure Low During Power Enrichment. He did also get the P0670 for the glow plug module.
Then after talking to his “source” they figured it had to be the Fuel pressure regulator. He said they were 90% sure it was the problem! So he changed that out, took it for a drive and could not get it to go into limp mode and called it fixed. This was this past Saturday Sept. 24. I picked up the truck and brought it home.
Monday morning I drove into town to my shop, which is about 30km away, then I drove back home and picked up my helper and we were on our way to do a pick-up about 45 km away in another town. We got 12km down the road and the truck went into limp mode again. No power, chugging and won’t go past 2000 rpm. WHAT THE F&@K
Now I had to break down and take the truck into the stealership. I have to get a proper diagnosis and get the dam thing fixed I depend on it to run my business.
They had it for a couple for hours and got the same codes off of it that the other guy did. P0670, and a low fuel pressure code ( I’m not sure if it was the P1093 code or not). They called me and said they “thought” it might be the Fuel Rail Pressure sensor, but they weren’t positive because they couldn’t get the truck to recreate the problem. I told them that they need to take it for a long drive and make it work, and it will happen. So they have it overnight and I’m waiting.
The past few nights I have spent hours searching this forum and some others for answers. No one seems to know the correct solution. Is there ANYBODY out there that can lead me down the right path? I'm into this for over $1000 so far and it is not fixed
:help PLEASE
here is my sig.
__________________
2004/5 2500HD GMC Seirra 4x4 SB Crew
Stock Truck No Mods, 6.6 LLY Duramax
:help PLEASE
here is my sig.
__________________
