1 - 20 of 22 Posts
I'm still in the middle of trying to get this flippin downpipe out of my truck. I have 2 questions.
how do I get the transmission dipstick tube lose? is there some type of clip holding it in that I am missing?
how many bolts are holding the downpipe shield on? I only found 2 but it feels like it is still attached
Thanks
it's gonna be a long night . I can tell you this definitely is not a 1 person job
Dip stick is bolted to the side of the tranny by 2 bolts if i remember correctly. Then it just slides out.
yep yep...
It helps to have a hand, I think theres 3 bolts in the shield ill have to run out to the garage to look. Its def. a real patience tester.
I just made it my b***h!
your right there was a second nut on the dipstick that I missed. came right up after that.
after I got it moved up I was able to access the third bolt on the shield
I then pushed the shield up and pulled it out the top and then finally was able to get the downpipe out of the bottom.
Now to reverse the whole process.
I still have to get the whole new exhaust put on tonight.
Ill check back in later when i have more problems.
Thanks guys
Good luck with the install, once you get the direct pipe on, the new exhaust should be a breeze.
F'n give her! Not looking forward to doing mine.
Diesel Junky
it sucks but well worth it:thumb, trimming the end of the dipstic tube makes a easier reinstall
cut that f***in heat shield with whatever it takes i used a sawsall a drimmel with a hard disk would have been better. best i can tell is just keep trying it took me like 3 hours just to get it out putting the new one on was easy as pie
Discussion Starter #12
OOh, u didn't put the bolt that was the original downpipe at the bottom. is it a problem that its not in.? can't remember if it held anything else.
Jank-A-Lank
the down pipe is not that bad, its the up pipe that will get ya ;) haha putting in the lb7 up pipe on my truck after my egr delete was funnnn
^ was backwards for me.. up pipes came off in like 20min..
so i got all jacked up for going home early.
4hrs later i had the stupid new downpipe on.. :rof
I STILL DGAF
Said this many times now but I was seriously ready to light my LBZ on fire because of the stupid downpipe. Webster's was lookin at adding the new cusswords I made up during the install.
1 - 20 of 22 Posts
