1 - 9 of 9 Posts
Can someone tell me if there is a factory egt probe on the engine for 2011 or are we still in the same boat as the LMM's????? Thanks...
the updated Insight CTS reads post turbo but no pre turbo. No probe in my exhaust manifolds that I see. I like I can read def level and range and soot level. FWIW
So the Insight is updated for the LML now?... Sweet
Yes I hAve the updated version, I am having lots of problems with it Mpg is way off it sayin I am getting 10 mpg empty. All kinds of issues
IMO the edge insights can be real flaky. Mine worked 73.254% of the time.
And I'd assume an lml to NOT have an egt sensor because gm only knows how to half way make a gauge cluster, much less a sensor for aftermarket gauges...
I don't know though.
I could however see them putting in a soot sensor or something like stated above. It's all about emissions now. Not about making it live. Lol
Discussion Starter #7
Thanks for the info....
Ok I have a 2015 lml and I did switch on the fly and delete. But the switch Hooked up to the EGT sensor I believe to get to the computer for the switch so my question is I am now wanting to do the edge CT three and I’m wondering if I have to get the probe with it or if it will be able to read the EGT’s because there’s more sensors? Thanks
It can read post Trubo egt if you want pretrubo you need the add on probe.
1 - 9 of 9 Posts
