If you are not willing to listen to good advice, you get what you pay for. I won't tell you what to do, but in my mind, you have not even determined that you have a fan issue.
If you do in fact, have a correctly working fan, then you HAVE ANOTHER PROBLEM, and that problem will not be remedied by replacing a fan which is doing what it is suppose to do. For example, if you MAP sensor is bad, you could be creating 10 psi more boost than you are suppose to. The heat from that malfunction, and many others, will create your condition.
Add to that, the Fan Clutch you are referring to, is 1000% more reliable than ANY electric fan configuration. It's your money. But get realistic, it is a fact these electric fans will only move about 30% of the air that the 21" HD fan clutch will. This is a very restrictive cooling stack. I can tell you also, there is no chance at all that you will pull 10,000 lbs on your grades, without spilling coolant, not in an otherwise stock LLY.
Also, have you scanned for OBD codes?
