So I will try to explain this as best I can. About 2 weeks ago I got home and heard a bad idler pulley and after I replaced it I was getting a really strange noise almost sounding like the fan hitting the shroud/guard, but it stopped almost right away and didn't come back until yesterday. I was backing my trailer in and when I use any power over idle it is making this loud shrieking sound. I crawled under and noticed the motor mounts where trashed so I swapped them out yesterday with rubber ones from the local parts house. The passenger side one was completely trashed, and the driver side I was able to finish pulling apart by hand. After I was done I checked it and it is still making the same noise. I have checked that the shroud is bolted down tight. I cannot make it make the noise in anything other than reverse, and only if the engine is off idle.
Here is a link to a video with the noise.
I am just sitting here scratching my head as to what else I need to check since it is only in reverse unless I received a bad mount and need to swap out the driver side again.
Discussion Starter #2
I found the issue to be the bolt around the fan surround under the air cleaner was missing. All is fixed now.
Thanks for closing the loop on this. It was classic symptom of motor mounts.
